XRAY X12 2017 1/12 Pan Car >
Like Tree9Likes
    Hide Wikipost
Old 03-17-2017, 02:50 AM   -   Wikipost
R/C Tech ForumsThread Wiki: XRAY X12 2017 1/12 Pan Car
Last edit by: R Dodge
Welcome to the XRAY X12'17 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. Many of us run the X12'17 on high bite carpet and with most US tracks going to the new black CRC carpet, most setups from here out will be developed for those high bite conditions.
Tips & Tricks:
Some racers notice slop developed in the front end over time. One method to reduce/remove this, as pointed out by some of our friends in Europe is to score the inside of the plastic front pivot ball (where the kingpin goes through) with a sharp xacto blade. Usually 4 scores at 12, 3, 6 and 9 will do. Alternative options can be found listed below.
As with any 1/12 pan car, a smooth operating suspension is critical to performance. It is recommended to polish your kingpins & hinge pins using a dremel or a drill and some sort of polish (IE Gravity polish or Mothers Aluminum polish will work). If you find that your suspension has a bind, you may look at using a reamer or drillbit to make sure the holes are clear of any flashing or debris. The only place this may happen is at the upper hingepin, which is 2mm dia.
For stock racing we usually find ourselves looking for a little more steering. One trick that some of the stock drivers have done that seems to help is lowering the graphite plate that the servo & shock mount to. To do this, you will need the 17mm standoffs from VBC and the servo mounts from the 2015 or earlier X12. Be careful that the servo mounts do not sit crooked on the plate when attaching it; a 0.2-0.5mm shim will help ensure it sits perfect on the graphite plate. Part numbers can be found below.
Option Parts to consider:
XRA371220 X12 Foam Bumper
XRA372012 Composite Front Upper Arm Mount – Right – Graphite
XRA372022 Composite Front Upper Arm Mount – Left – Graphite
XRA372113 Composite Suspension Arm Front Lower – Right – Graphite
XRA372123 Composite Suspension Arm Front Lower – Left – Graphite
XRA372177
Spring 4.75 Coils 3.6x6x0.45mm, C=2.0 - Silver (Soft) (2)
XRA372178
Spring 4.05 Coils 3.6x6x0.45mm, C=2.5 - Black (Soft) (2)
XRA373584 Side Spring C=0.6 - Silver (2)
XRA373586 Side Spring C=1.2 - Black (2)
XRA375010 Graphite Rear Axle Shaft - highly recommended
XRA378094 Shock Spring C=2.1 – Black
Lowered Graphite Plate:
B-02-VBC5005
XRA376255-O Alu Servo Mount - Orange (2)
Front end options:
ASC4403 Kingpins, 1:12 Scale
ASC4622 Upper Arm Eyelets
ASC4626 Upper Arm Mounts/Steering Blocks
ASC4627 Front Axles
ASC8417 Pivot Balls
Aluminum Chassis:
Max.FX Aluminum Chassis
McFactory Motorsports
Reflex/RSD
Recent Setups:
Alexander Hagberg - Snowbird Nationals - Mod - High Bite
Craig Xavier - Snowbird Nationals - 17.5 - High Bite
Robbie Dodge - Snowbird Nationals - 17.5 - High Bite
Eric Anderson - ROAR Carpet Nationals - 13.5 High Bite
Print Wikipost
Old 08-10-2016, 10:00 AM
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Default XRAY X12 2017 1/12 Pan Car
XRAY X12'17 Coming Soon
Attached Thumbnails XRAY X12 2017 1/12 Pan Car-xr-x12-17.png
RC MARKET is offline
Old 08-11-2016, 03:33 AM
Car Breaker's Avatar
Not even a low res spy shot ? I had x12 2013, 2014, 2015,and 2016. They charge more and more each year,I hope the price dont get any higher. I can almost get a ARC R11 touring for how much xray charge for their X12 2016
Car Breaker is offline
Old 08-11-2016, 12:18 PM
Trader Rating: 24 (100%+)
Hopefully they're minor changes so we can update our cars! Be interesting to see what happens.
fenton06 is offline
Old 08-13-2016, 05:31 PM
Trader Rating: 11 (100%+)
Can we not have a new thread and just combine this with the 2016 one?
cplus is offline
Old 08-13-2016, 06:31 PM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Maybe a front end that isn't sloppy for the new car.
Dan is offline
Old 08-13-2016, 07:16 PM
I doubt it...
fenton06 is offline
Old 08-14-2016, 03:30 AM
RC MARKET's Avatar
I'm think have a new motor mount !
Motor mount rear side change to use Graphite , don't use alu. post .
or Servo can move to Front side
Old 08-20-2016, 10:06 AM
Suspended
http://www.liverc.com/news/special_f...World%27s_car/
Shorter tubes, new rear pod w/ angled CF brace, motor moved over and the option to run the links straight or toed in. Plus some more goodies not shown in these pics.
R Dodge is offline
Old 08-31-2016, 02:22 PM
Zerodefect's Avatar
Hint: Exacto knife. Or just upgrade to the steel balls.
http://forum.teamxray.com/viewtopic.php?f=24&t=18988
Zerodefect is offline
Old 09-01-2016, 10:43 PM
When should we expect some more details on the new x12-2017
truggy100 is offline
Old 09-02-2016, 02:50 AM
Suspended
Last year Xray announced the X12'16 on September 3, released details on September 18 and announced that it was shipping on September 22. I would imagine we will see details in the coming week or so, but I have no info on when they will release them. A lot of us thought details were coming during Worlds, but it just didn't work out that way unfortunately.
From what I've seen and heard about the new car, there are some nice changes coming & I'm excited to get it on track.
R Dodge is offline
Old 09-02-2016, 08:03 AM
Suspended
I think you guys will be happy with the changes made on this car. It goes together like you would expect a Xray car to as well.
Chris Adams is offline
Old 09-02-2016, 01:39 PM
Did they make any changes to the main chassis?
fenton06 is offline
Old 09-02-2016, 03:20 PM
haywood's Avatar
Trader Rating: 49 (100%+)
Default 2017
Please don't send the damn steel axle!
haywood is offline
Old 09-02-2016, 03:32 PM
jason cheng's Avatar
Trader Rating: 86 (100%+)
You hit a lot of shit you will bend it
jason cheng is offline
